Configures RIP on an IP interface.
| vlan_name |
Specifies a VLAN name. |
| all |
Specifies all VLANs. |
N/A.
When an IP interface is created, RIP configuration is disabled on the interface by default. When the RIP interface is disabled, the parameters are not reset to default automatically.
The following command configures RIP on the VLAN finance:
# configure rip add finance
This command is available on all platforms with a Base license or higher as described in the Switch Engine v33.1.1 Licensing Guide document.
